This is the support topic for the tutorial DRL's - Retrofit to your Duster. Please post here if you have any questions or helpful advice to offer.
Can some one tell me as to where the control box is fitted for the DRL's in the engine compartment as I have bought the kit and am ready to installThis is the support topic for the tutorial DRL's - Retrofit to your Duster. Please post here if you have any questions or helpful advice to offer.if
I've just left mie sat on the chassis rail in front and below the battery. it has lips either side of it so it can't fall off unless I turn the car over.Can some one tell me as to where the control box is fitted for the DRL's in the engine compartment as I have bought the kit and am ready to installNick said:This is the support topic for the tutorial DRL's - Retrofit to your Duster. Please post here if you have any questions or helpful advice to offer.if
I've downloaded a pic of mine to this thread hope it helpsI have found the location to fit the controller but I can't find the wire loom for the side lights. I can see the cables if I take off the rubber cover to replace the lamps but don't see the wiring loom. Do you have to take a cover off to get at the loom. Can anyone help ?
Steve Thanks for the photo, I did see that plug but I thought the wires were to thin for the headlights and the plug was for something else. I will fit them this week RonI've downloaded a pic of mine to this thread hope it helps
glad to be of help Ron. The cable I've spliced too is the pink n blue oneSteve Thanks for the photo, I did see that plug but I thought the wires were to thin for the headlights and the plug was for something else. I will fit them this week Ron
Hopefully with the help of the photo and your added info on the cable i will be able to get them working, Thanks again Steveglad to be of help Ron. The cable I've spliced too is the pink n blue one
let me know how you do Ron Ron a do Ron Ron ?Hopefully with the help of the photo and your added info on the cable i will be able to get them working, Thanks again Steve
Steve I went out to fit them, I thought I could take the top grill off so that I could clip and feed the cables but that is part of the whole bumper, I then had a go at the bottom grey panel but that is part of the bumper. How did you manage to feed and secure the cables for the lights? Ronlet me know how you do Ron Ron a do Ron Ron ?
that's the fiddley bit. Get a bamboo cane and tape a hook to the end and you can get hold of the cable through the grill and feed it allong so both cables end up at the bottom right of the radiator, then use it again to pull the cables up the side of the rad to the top.Steve I went out to fit them, I thought I could take the top grill off so that I could clip and feed the cables but that is part of the whole bumper, I then had a go at the bottom grey panel but that is part of the bumper. How did you manage to feed and secure the cables for the lights? Ron
im always serious! That's why everyone calls me "the serious stevester"Steve Are you being serious for the first time on this Forum??? (Apart from the Do Ron Ron Ron De Doo Ron Ron)
Steve after I left you the message about how to feed the cables last night I went on the web to search for a workshop manual for the duster to see if that would help and I managed to get one on disc in English PDF file. It's coming from Portugal.that's the fiddley bit. Get a bamboo cane and tape a hook to the end and you can get hold of the cable through the grill and feed it allong so both cables end up at the bottom right of the radiator, then use it again to pull the cables up the side of the rad to the top.
no probsSteve after I left you the message about how to feed the cables last night I went on the web to search for a workshop manual for the duster to see if that would help and I managed to get one on disc in English PDF file. It's coming from Portugal.
The fitting of these lights are becoming a challenge as there is certainly not a lot of room to manoeuvre under the bonnet. and you cannot gain access from underneath I have bought the reversing sensors and the PDF on the forum for fitting seems a lot easier than fitting DRL's even although there is a lot more involved . Thanks again for your assistance Ron
