Does anyone have any idea why when operating the 4X4 switch it springs back to auto.setting.
That's default. The actual setting being used is shown on the dash. 2WD and 4x4 show otherwise auto does not indicate.
Yeah just to elaborate, having 4WD on all the time would not be beneficial, you should only be using it in times of need this is why it always defaults upon start-up to either 2WD or AUTO which is where it picks the best setting for the terrain.
If it says 4WD on the dash then it is in 4x4 mode,
Thanks for replies, the reason asking is that i had a Xtrail with same switching and as far as i can recall in thick snow when i operated the 4X4 switch it did not spring back to auto.
