1 - 1 of 1 Posts
Hi all,
Has anyone had the electronic battery sensor fail on their Dacia? The error code I found says the sensor is out of range. The battery has been checked and appears fine, but is not charging more than 95%, so the start/stop is not working either.
If it's not the sensor failing, any other ideas?
Cheers!
Mike
1 - 1 of 1 Posts
