1 - 12 of 12 Posts
Has anyone else experienced the ABS & Traction control light coming on on a Duster in damp weather? Its happened twice now-about a month ago and this morning. Both early morning and both in foggy, damp conditions. I suspect its damp getting into some wiring somewhere that a bit of WD would sort. But where to spray?.....
Sounds like something is up.. atleast on the 2013 and earlier models that light rarly comes on even when the tires is spinnin.
Do a search for "3 Amigos" and you will get lots of info on the Land Rover Discovery which throws up ABS, Traction Control and 1 other warning light. Obviously a different car but if the ABS system works the same then it might give some pointers as to how this could be solved on a Duster.
Thanks for that guys, its not done it since despite some very wet weather. I'll keep an eye on it.
You werent per chance doing a 4 wheel drift at the time were you? :)
That would get em flashing
agree though, dont interfere yourself, get warranty on it
Yes - Car in the garage the 3rd time with this issue.
Always wet days, and won't start.
ABS pump was replaced 2 weeks ago, and happened again 2 days ago.
Have you had any more issues regarding this?
Thanks, the dealer and CS seem baffled by it. So I thought I'd have a search to see if I could find anyone else with the same issue.
They've had the car since first thing Monday morning, and are still none the wiser.
Did anyone find out the issue with the anti skid control light coming on when driving in damp conditions ?
My light is staying on all the time
Had the local guy do a diagnostics on it and its saying uch and nothing else !
Can anyone elaborate on what that might be The cars a 2015 Duster 2 wheel drive 14oo cc Diesel with 30000 miles
Cheers
1 - 12 of 12 Posts
