1 - 3 of 3 Posts
Hi i am new to this so i hope i get it right. I have had a stepway for about a month now but yesterday was the first time i used it in the dark, I have found the headlights are way out of line with each other how can this be rectified or should i take it back to the dealer to sort. I know there is an adjuster down by drivers feet but that only moves the headlight up or down it does not align them. Any one help on this matter please.
Hiya,as you've only had your steppy a month,I would suggest a trip back to the dealer to have a look at/rectify as it could be a faulty headlight unit,which if needs replacing,wouldn't be a cheap fix.......best of luck,I hope you get it sorted ASAP.
Regards,
CM.
1 - 3 of 3 Posts
