Aerial Base and Rear Windscreen Water Jet Blockage
169 views 4 replies 3 participants last post by  Paul001
#1 ·
Hello
1) I have a 2018 plate Stepway, which I am quite pleased with. However, (My Fault) I went to a car wash and the aerial broke. On inspection the Aerial base needs to be replaced. I am wondering if a replacement from ebay would do the trick. I do not know whether the wiring from a new Aerial Base would just be a plug in? or is it hard wired? Any help would be appreciated.
2) Rear Windscreen Pipe Blockage. I have removed the nozzle and there is no water coming from the pipe on the rear tail gate. Pumps are working fine. Has anyone got any ideas on how to unblock the pipe? Many Thanks Paul
#3 ·
Try pushing a thin bit of wire in the jet to see if that clears it, then put some vinegar in the screen wash bottle to dissolve any lime in the system.
when the system is clear drain the screen wash tank and fill with distilled water and screen wash.
Never use tap water as it is contaminated.
I did this to my toilet to stop it dripping down in to the bowl It worked over night in that situation.
