Sorry for the boring post but do you know if the aerial on the Duster is the same fitment as a Renault?
I'd like to swap the aerial for a smaller one so it looks less like a radio controlled car.
No idea about the renault aerial but if you look at my thread in Duster electrical you'll get some idea of what is involved in changing it. I will say that the Dusters aerial is fitted very far forward, on a sharp forward slope and very close to the edge of the windscreen, the hole through the roof is small. I changed mine for a DAB aerial and any other aftermarket ones I've seen have the same problem, the base is just too big to fit well and look 'right' without extra work.
I wasn't looking to change the fitment as such just the aerial that you can unscrew.
Happy with the fitment but I suspect it is the same size thread as the older Renaults. Certainly looks identical.
Suppose I should be patient and test it when I get home since I have a Clio sat right next to the Duster but I was prowling eBay and wanted to order one. lol
Ah yes!, I call it "getting a spend on" :)
The Dusters aerial looks very like the Renault Traffic one if that helps.
they are the same
u can unscrew this one and fit a shorter one
