2013 logan 1.5 DCI airbag issue now won't start. The airbag recently came on with the seat belt light. Checked connections under both seats. Not showing anything on a generic obd reader.
Someone suggested disconnecting the battery to see if it dumped ecu codes. Disconnected for 30 mins reconnected and now it won't start . Seems like the fuel pump is inhibited. Don't think its an immobiliser issue as central locking works. Anyone got any ideas as car is now stuck outside the house.
While I can not help with the fault the central locking and immobiliser are two different systems.
So why did you post this?
What happens when you try to start does the starter motor work or do you just hear a click which is the starter motor solenoid?
It cranks over fine, its , seems to me fuel pump is locked out.
maybe sticky pump, have someone thump the tank from underneath
while you crank it over, any blown fuses ?..........
