1 - 3 of 3 Posts
A traction control system (TCS), in German known as Antriebsschlupfregelung (ASR), is typically (but not necessarily) a secondary function of the anti-lock braking system(ABS) on production motor vehicles, designed to prevent loss of traction of driven road wheels. When invoked it therefore enhances driver control as throttle input applied is mis-matched to road surface conditions (due to varying factors) being unable to manage applied torque.
Intervention consists of one or more of the following:
  • Reduces or suppress spark sequence to one or more cylinders
  • Reduce fuel supply to one or more cylinders
  • Brake force applied at one or more wheels
  • Close the throttle, if the vehicle is fitted with drive by wire throttle
  • In turbo-charged vehicles, a boost control solenoid can be actuated to reduce boost and therefore engine power.
Typically, traction control systems share the electro-hydraulic brake actuator (but does not use the conventional master cylinder and servo), and wheel speed sensors with the anti-lock braking system.
History[edit source | editbeta]
The predecessor of modern electronic traction control systems can be found in high-torque, high-power rear-wheel drive cars as a limited slip differential. A limited slip differential is a purely mechanical system that transfers a relatively small amount of power to the non-slipping wheel, while still allowing some wheel spin to occur.
In 1971, Buick introduced MaxTrac, which used an early computer system to detect rear wheel spin and modulate engine power to those wheels to provide the most traction.[citation needed] A Buick exclusive item at the time, it was an option on all full-size models, including the Riviera, Estate Wagon, Electra 225, Centurion, and LeSabre.
Cadillac introduced the ill-fated Traction Monitoring System (TMS) in 1979 on the redesigned Eldorado. It was criticized for its slow reaction time and extremely high failure rate.[citation needed]
Overview[edit source | editbeta]
The basic idea behind the need of a traction control system is the difference between traction of different wheels evidencing apparent loss of road grip that compromise steering control and stability of vehicles. Difference in slip may occur due to turning of a vehicle or differently varying road conditions for different wheels. At high speeds, when a car tends to turn, its outer and inner wheels are subjected to different speed of rotation, that is conventionally controlled by using a differential. A further enhancement of the differential is to employ an active differential that can vary the amount of power being delivered to outer and inner wheels according to the need (for example, if, while turning right, outward slip (equivalently saying, 'yaw') is sensed, active differential may deliver more power to the outer wheel, so as to minimize the yaw (that is basically the degree to which the front and rear wheels of a car are out of line.) Active-differential, in turn, is controlled by an assembly of electromechanical sensors collaborating with a traction control unit.
Operation[edit source | editbeta]
When the traction control computer (often incorporated into another control unit, like the anti-lock braking system module) detects one or more driven wheels spinning significantly faster than another, it invokes the ABS electronic control unit to apply brake friction to wheels spinning with lessened traction. Braking action on slipping wheel(s) will cause power transfer to wheel axle(s) with traction due to the mechanical action within a differential. All-wheel drive AWD vehicles often have an electronically controlled coupling system in thetransfer case or transaxle engaged (active part-time AWD), or locked-up tighter (in a true full-time set up driving all wheels with some power all the time) to supply non-slipping wheels with (more) torque.
This often occurs in conjunction with the powertrain computer reducing available engine torque by electronically limiting throttle application and/or fuel delivery, retarding ignition spark, completely shutting down engine cylinders, and a number of other methods, depending on the vehicle and how much technology is used to control the engine and transmission. There are instances when traction control is undesirable, such as trying to get a vehicle unstuck in snow or mud. Allowing one wheel to spin can propel a vehicle forward enough to get it unstuck, whereas both wheels applying a limited amount of power can't get the same effect. Many vehicles have a traction control shut off switch for just such circumstances.
Use of traction control[edit source | editbeta]
  • In road cars: Traction control has traditionally been a safety feature in premium high-performance cars, which otherwise need sensitive throttle input preventing spinning driven wheels when accelerating, especially in wet, icy or snowy conditions. In recent years, traction control systems have become widely available in non-performance cars, minivans, and light trucks.
  • In race cars: Traction control is used as a performance enhancement, allowing maximum traction under acceleration without wheel spin. When accelerating out of turn, it keeps the tires at optimal slip ratio.
  • In motorcycles: Traction control for a production motorcycle was first available with the BMW K1 in 1988. By 2009, traction control was an option for several models offered byBMW and Ducati, and the model year 2010 Kawasaki Concours 14 (1400GTR).
  • In off road vehicles: Traction control is used instead of, or in addition to the mechanical limited slip or locking differential. It is often implemented with an electronic limited slip differential, as well as other computerized controls of the engine and transmission. The spinning wheel is slowed down with short applications of brakes, diverting more torque to the non-spinning wheel; this is the system adopted by Range Rover models in 1993, for example. ABS brake traction control has several advantages over limited-slip and locking differentials, such as steering control of a vehicle is easier, so the system can be continuously enabled. It also creates less stress on powertrain and driveline components, and increases durability as there are fewer moving parts to fail.[1]
When programmed or calibrated for off road use, traction control systems like Ford's four-wheel electronic traction control (ETC) which is included with AdvanceTrac, and Porsche's four-wheel automatic brake differential (ABD), can send 100 percent of torque to any one wheel or wheels, via an aggressive brake strategy or "brake locking", allowing vehicles like the Expedition and Cayenne to keep moving, even with two wheels (one front, one rear) completely off the ground.[2][1][3][4][5]
Controversy in motorsports[edit source | editbeta]
Very effective yet small units are available that allow the driver to remove the traction control system after an event if desired. In Formula One, an effort to ban traction control has led to the change of rules for 2008: every car must have a standard (but custom mappable) ECU, issued by FIA, which is relatively basic and does not have traction control capabilities. NASCAR suspended a Whelen Modified Tour driver, crew chief, and car owner for one race and disqualified the team after crossing the finish line first in a September 20, 2008 race at Martinsville Speedway after finding questionable wiring in the ignition system, which can often be used to implement traction control.
Traction control in cornering[edit source | editbeta]
Traction control is not just used for improving acceleration under slippery conditions. It can also help a driver to corner more safely. If too much throttle is applied during cornering, the drive wheels will lose traction and slide sideways. This occurs as understeer in front wheel drive vehicles and oversteer in rear wheel drive vehicles. Traction control can prevent this from happening by limiting power to the wheels. It cannot increase the limits of grip available and is used only to decrease the effect of driver error or compensate for a driver's inability to react quickly enough to wheel slip.
Automobile manufacturers state in vehicle manuals that traction control systems should not encourage dangerous driving or encourage driving in conditions beyond the drivers' control.
source http://en.wikipedia.org/wiki/Traction_control_system
Intervention consists of one or more of the following: ............ etc
Umm! Andrew, your post suggests there is an electronic input to the K9K DCI's turbo effect/engagement. That would make sense of the Duster Driver's Manual saying something about switching ESP off in 4WD mode to avoid reduction in power (or some such wording). So, while I am accepting that my turbo IS working after-all (ref. other threads) and is kicking in at lower revs than I had originally expected, I shall bear your post in mind because there are still times when I think "come on Fluffy, fire up your turbo for goodness sake"! :huh:
1 - 3 of 3 Posts
