1 - 2 of 2 Posts
Hi all,
For reference, I have a 2014 4wd duster DCI 110.
I'm having trouble diagnosing a non-functioning boot/trunk courtesy light.
I've changed the bulb with no success.
I've eliminated the switch in the boot lock as the rest of the interior lights turn on when the boot is opened.
I did a bit of wire chasing to look for damaged wires and got to the rear bench before running out of time.
Does anyone have any suggestions for what to try next? Or has anyone experienced this before?
Thanks!
The boot light has nothing to do with the boot being open. It is a rear courtesy light and controlled by the central locking.
When the front courtesy lights comes on when you unlock the car so should the boot light. It should also timeout at the sane time when you lock.
Hope this helps.
1 - 2 of 2 Posts
