1 - 2 of 2 Posts
my dacia Logan car temperature jumps up once I
turn the A/C on and drive for a while. it gets to the
maximum after a while depending on the weather?
please what needs to be fixed?
I would expect a small rise in coolant temperature but if as you say the gauge is maxing out you have quite a serious problem that needs to be fixed.
There is a number of components that could be the culprit, so its not really possible to do a remote diagnosis, please take you car to someone who car repair it. And don't drive around with the coolant temp off the gauge, you'll likely blow a head gasket or worse.
1 - 2 of 2 Posts
