That lets you do no damage to the wiring and you can take it all out before taking it back for a warranty claim if you need to. So nobody needs know you have even done it.
I went for the feed to the cig lighter on the centre console. The original wiring for that now plugs in to a 'junction' I made which takes a feed off for the dash cam before continuing to the cig lighter. No changes or breaks to the vehicles original wiring loom.
I had my Road Angel Dash Cam Hardwired in by the dealer. It needed 3 connections 1 permeant live, 1 through the ignition and earth. 1st attempt by dealer failed as they thought they had found a permeant 12v feed but it was switched off when the alarm was set as are most of the electrics. So went back for another go they had to run a wire direct from the battery with an inline fuse I assume as they fitted it wont effect the warranty.
