1 - 20 of 22 Posts
dCi 90 1.5 K9K Service Programme
Service Interval 12K or 1yr
Oil Change OCS upto 12K or 1yr
Oil Filter OCS upto 12K or 1yr
Cabin Filter 12K or 1yr
Air Filter 36K or 4yrs
Fuel Filter 36K or 4yrs
FAP When blocked
Timing Belt 72K or 6yrs
Accessories Belt 72K or 6yrs
Coolant 72K or 5yrs
Brake Fluid 72K or 4yrs
Service Checks - Refer to Service Programme Check Sheet RL236 for the checks to be carried out at each service interval
OCS - (Oil Control System) uses the engine's ECU to calculate servicing intervals as a function of the way the vehicle is used. Should running conditions be considered too severe (e.g. mainly short journey urban motoring) a warning on the dashboard invites the driver to bring forward the next oil change. OCS enables longer oil change intervals while at the same time providing a solution that protects those owners whose driving . OCS employs an algorhythm which notably takes into account the vehicle's road speed and engine speed.
FAP - Diesel Particulate filter replaced when blocked.
Does anyone have a copy of Service Programme Check Sheet RL236 they can share?
Mine turned 12,000 last week but no light has come on yet for a service requirement.
I wonder if the maths is exact, ie 20,000 km sevice interval is 12,427½ miles?
Anyone seen there light come on yet?
Mechanic that did my oil change, thought he had the wrong size sump plug remval tool until he realized that the plug was fitted less than hand tight!!
However the oil filter had obviously had the opposite amount of force applied and needed the bracket removing from around the outside to get the required force needed to remove with a filter wrench.
Obviously the earlier problem is more of a worry. :angry:
both have to be tightened to the hand strength not by wrench
the plug to the oil pan has to have a copper ring on it
How do you tighten to hand strength on a sump plug that is square internal drive with a smooth round external surface?
Sump plugs do indeed have a torque setting and most are in the 20 - 25 Nm
You stick in the Plug (sump) Spanner or stick it on and Pull tight till you cannot move it anymore ! I have never used a torque wrench on a sump plug and would never dream of doing so ! also the filter only needs hand tightening
my english wasnt quite perfect
i meant of course use a key a wrench
but at the end turn just 15 minutes a 1/4 quarter
about the force to which the plug its tightened
and the oil filter must be install all by hand and tightened only by hand
using a key on a new oil filter its risk to puncture the oil filter its self
im not stupid u dont need to post pictures of the plug
As listed at the start of this, sump plug could be spun off without any bar or ratchet needed. To loose and dangerous especially with a rattly diesel engine.
Oil filter had been applied with far to much force which mean't removing other metal work to get the necessary purchase required to undo with a filter wrench.
Torque wrenches only exert the pressure dialed into them and should be used to tighten almost all bolts (but not an oil filter as this tightens onto a rubber ring by hand). One persons hand tight is not equal to everyone else's hence the need to standardise with torque settings.
the oil filter when install u put a little bit of oil on the rubber ring
tight by hand
because of the hot temperature the engine is running
the rubber sills on to the engine thats why after 10 15000km
its so tight and because its hot when u have to remove it u need a key a wrench
cos to drain the oil properly u have to have it warm hot
http://en.wiktionary.org/wiki/hand-tight
I would have thought it was self explanatory
Nice simplistic ideal, however my hand tight is more than my wife's but less than say arnold schwarzenegger, you then move onto the tool being used are they all the same length? if not then the force applied again radically changes.
But maybe Renault are wrong for giving a torque setting in there service manuals and a hand tight, or a ¼ turn or nipping it up is the right thing to do!
as a car manufacturer they are oblige by legislation
to put in the manual all the torque settings for all the operation all the features of nuts bolts screws
u find this in all service manuals for all car brands
I know what I mean :p I suppose that is what counts ! ! and Hey how many of you (Honest !!!! ) will be changing there own oil
Its a bit like McDonalds having to say the coffee is hot
LOL me after the warranty expires, if I can't afford to change the car.
Oil and filter changes by dealerships is a complete rip off.
u do it at a ordinary service garage
by the stuff and the work must be smth like 5 quid
here i get it for 20bpounds oil and filter and air filter
a beer or 5 bpounds to my mate the mechanic
job done
1 - 20 of 22 Posts
