DRIVINGECO², RENAULT/DACIA ECO-DRIVING
As an automaker, Renault's duty is to provide novel solutions that help its customers reduce their fuel consumption and, at the same time, curb the production of greenhouse gases.
Motorists can play a major part in reducing the fuel consumption of their vehicle. Eco-driving entails drivers going easy on their vehicles, which should be serviced properly and adapted to their needs.
DRIVINGECO² can reduce fuel consumption by up to 20%
Tip n°1 : Improve your gearshifts
> At 50kph, you should already be in fourth or fitth gear.
Tip n°2 : Drive smoothly
> At 50kph in fifth gear, lift off the accelerator 100 metres before a red light.
Tip n°3 : Thing about how you accelerate
> Change gear very swiftly up to fitfh gear.
Tip n°4 : Climbs and descents
> Use descents to take your foot off the accelerator.
Tip n°5 : USe your motor smartly
> Pull away as soon as the engine has fired up.
Tip n°6 : Treat your vehicle well
> Proper servicing and proper use of your vehicle are as important as eco-driving.
source:
http://www.renault.com/en/capeco2/eco-conduite/pages/eco-conduite.aspx
- Shift down at approximately 1,000rpm
- Shift up to the next gear at apporximately 2,000rpm in diesel vehicles and at 2,400rpm in a petrol engine
- Maintain a steady speed as soon as possible (from 40kph)
- Brake with the engine and use your foot brake as little as possible. Allowing the vehicle to slow naturally helps to cut the fuel flow
- Up to 50kph, it is preferable to accelerate briskly up to fifth gear
- At speeds in excess of 50kph, acceleration should be restrained
- Keep to the same speed when going down a hill
- On an uphill gradient, let the car shed speed, but without becoming obstructing other
road-users. If possible, maintain your vehicle at a steady speed above 40kph
- Turn off your engine if you stop for more than 30 seconds
- Do not preheat your engine even in winter
- Check tyre pressures every month
- If you have to use the air conditioning, make sure the difference between the temperatures inside your vehicle and outside is not too great
- Do not leave any unnecessary loads in your vehicle
- Remove roof bars and roof boxes when not in use
source:
