1 - 8 of 8 Posts
Hi
I have a new Duster Laurente (2014 version) with factory fitted options of Touring and Protection kits.
The Protection kit has reversing sensors and the Touring adds a tow bar.
The handbook says to disable the reversing sensors if towing but there does not appear to be a switch anywhere!
The manual shows one near the MediaNav but it is not present on my vehicle.
Can anyone help?
Thanks Jim
Reverse sensors will be disable when u plug a trailer in. If they are fitted properly. No switch on our model of duster.
well they done on a 2013 Duster as i have the touring pack and protection pack and mine has been into the local dealer to have it checked as when i hooked my caravan up the fridge and charging circuits weren't working (but i just put up with the beep when reversing with my caravan hooked up
Should turn off the sensors if it's wired in properly. I fitted my towbar. I connected part of the loom to the towbar electrics to the parking sensor control box and when you plug in a trailer it breaks a circuit and they don't switch on.
it could be that i have a converter plugged in that converts from 13 pin to two 7 pin sockets
1 - 8 of 8 Posts
