1 - 3 of 3 Posts
Discussion Starter · #2 ·
for those of you wishing to fit a towbar - this may be helpful to you.
The THULE does not require a bumper cut(something I did not want to do) --- the Witter does need cutting apparently.
as in many instructions to fit things, the instructions are abysmal - the location of the holes in the rear chassis arms was rather elusive - so ----
imagine you are lying on your back looking up at the boot floor and the 2 chassis legs - you will see a transverse box section going across the car between the 2 chassis legs - measure approx 3" backwards towards the bumper for the first hole and you will find it - push through and your screwdriver will pop out inside the cubby hole where the jack and wheel brace lives - the mounting bolts go from this cubby hole into the centre of the car and pick up the towbar plates - easy when you know where the holes are !!!!!!!!!!
the THULE needs the heat plate removing above the silencer to give you extra space - replace after job done.
I've just bought a witter towbar, arrived last night, awaiting electric kit coming, will be fitting this weekend.
thanks for the measurements to find holes..
If anyone wants any info on fitting will post up next week.
1 - 3 of 3 Posts
