My duster keeps getting air in the fuel so often after standing I need to prime the bulb, car then starts and runs. Upon examination I can see a split at the bottom of the primer bulb where the rubber wraps around the harder connection section so I suspect this might be the root of the problem Does anyone know if the bulb can be replaced alone or does it require the whole fuel line. The line is nylon and seems permanently Attached to the bulb. Also where might I get part(s) on-line.
Also is there an air bleed screw anywhere or does just pumping clear the air?
