1 - 20 of 23 Posts
Did anyone who has taken delivery of a Duster get a locking petrol cap on the car?
It was in the specifications when i ordered mine, but on seeing my vehicle at the dealer pre-delivery, it is not fitted. I realise they sometimes change specification without warning, but I'm interested to find if I'm the odd one out!
Mine is a Diesel too and it also has the locking cap as pictured above.
I will have to check with one of my mot testing customers but I am sure if the outer petrol flap is locking central or key you don't need a locking cap. everything else requires a locking cap to be fitted to pass an mot.
woah......thats pricey...! But peace of mind knowing the fuel you put in won't be nicked or siphoned off, and over the years that adds up to £1000's, then it seems good money well spent to me :)
Found this for you after doing a search on the Forum. ;)
Posted by scottie55 on 27 March 2013 - 05:07 PM in Dacia Duster Forum
I want to get a locking fuel cap for my Duster 4x2 Access (petrol).
Any suggestions on where I can get one and am I looking for vented or non vented?
I bought mine from http://www.petrolcaps.com for £17.99. Seems to be a perfect fit
Reactions: Troute
That sounds more like it Tozci :)
Have to buy the petrol cap for the duster £58.00
Why? Dacia should be putting this right as according to http://www.mot-test.net/mock-test/fuel-system/ no locking cap = MOT failure.
Common faults
  • Fuel leaks. Any fuel leak will result in an MOT test failure. Not only does a fuel leak present a fire risk, but it can also cause a hazard for other road users if fuel is spilled onto the road surface.
  • Incorrect fuel cap. To pass an MOT test the fuel system must be complete with a locking fuel filler cap. If the cap can't be locked then the vehicle will fail the MOT test.
  • Fuel tank condition. If the fuel tank is in a bad condition this can often result in an MOT failure. For example advanced corrosion or serious road damage may cause the tank to be unsafe.
  • Fuel pipe condition. Corroded or damaged fuel pipes can be the cause of a failed MOT test. Advanced corrosion can lead to fuel leaks.
Formally "2Dusterschris"
There's no requirement to have a lockable fuel filler cap to pass the MOT. The cap simply needs to be secure and form a good seal.
I cannot find a VOSA reference for you but have put 2 Fiat Panda 4x4s through MOTs without locking fuel caps, the most recently was in October last year. No problems encountered.
Good to know - just read through the VOSA ref which agrees with your view. Still a bit of an odd omission not to fit a lockable cap. Even my old £5400 agila had one... and a stereo !!
http://www.dft.gov.uk/vosa/repository/CONT071791.pdf
See page 3 of this document. I think that the requirement that the key to the fuel filler cap is available might be interpreted by some as a need for a lockable filler cap. It isn't, it is there to ensure the MOT tester can examine the filler cap properly if it is lockable.
Common faults
I spotted exactly this page on the web. Discussed it at some length with the engineer who does the MOTs at my dealers. He assures me that he would pass a Duster Access with the non locking petrol cap. He says the regs , above , mean that the cap must have a positive click tightening action which pulls it into the filler tube. He is adamant that it does not mean that the cap must have a key lock.
This clashes with Dacia CS who told me that the non key locking cap on my Access Duster was incorrect and that I should contact my dealer ! I tend to believe the " dealer man " who does the MOTs himself.
Common faults
by locking fule cap they mean a cap on the fuel tank that locks shut to fuel or fumes do not come out.
the locking by a key is optional.
1 - 20 of 23 Posts
