1 - 11 of 11 Posts
With both windows up, then using 1 finger each for the front windows start lowering both together. Almost immediately remove finger from either button but both windows continue to open.
Doesn't work when closing nor on the rear windows
Can't remember if it's the same on my Duster but the van windows certainly go down and up all the way with one short press, a long press and they stop when you let go.
Common feature on most cars these days' its called one touch opening and the idea is you just press the button again at the point you want your window open' its also a godsend at the drive thru McDonalds
No, it doesn't do that, have to keep pressing. But it opens both front windows even if lift finger off of one of the 2 buttons
I understand what your saying now, start moving both windows, then let go of one button and keep the other passed, and both windows keep moving.
That sounds like a fault, go and see the dealer.
Dont think that any version of the Duster has one-touch opening. My Laureate certainly doesn't.
1 - 11 of 11 Posts
