Fault with idle and irregular fuel supply error analysis is fuel input regulator. Problem can't buy from dacia without buying full injector system. Part looks similar to many on the market but fitting holes not in a straight line.
Advice welcome.
Body jewelry Asphalt Grey Road surface Headgear
Does it have any part numbers on it as it'll make searching easier. The position of the mounting holes look like it should be the three hole mount type?
Only 2 fixing holes, no number on main body. The number on little white plastic thing is D or 0F01 0324.4
Thanks for help
