Hi anyone changed the Low tone standard fit horn? if so where did you mount the horns.
Vstrom
Discussion Starter · #2 ·
I have now fitted Bosch twin tone horns and they sound a lot better! than the standard fit horn.
Vstrom
were they expensive ?
and how easy were they to fit as peeped horn at someone today and I didn't even hear it.
I recommend the Hella Supertones. One of the loudest horns you can fit without needing an air compressor.
Vstrom
Can we see some photos of where you mounted them?
Hi
The Bosch horns that I fitted were taken out of another car I had ,so they are not new. I run the power through a new 30amp relay just in case.
Easy to mount all I did was remove the bonnet cable plastic retainer which gave me a ready made mounting hole, so no need to drill another hole in the car.
They sound great compared to the standard fit single Low tone horn, and all it cost me was the 12v relay as I had the horns.
Vstrom
