Hi All
How do I replace Dacia Sandero Stepway Laureate Tce (0.9) passenger side wing mirror unit?
Totally broken off so need a complete new unit. Trying to remove the interior panel - is this simply pop off with a screwdriver or is there something I should do first?? Help - very new to this! Also - can anyone share a link for the correct unit to buy?
Dan
Automotive tire Automotive lighting Motor vehicle Automotive mirror Vehicle
Are you claiming on insurance? Isn't it a body colour mirror?. They don't come painted only primed. The last time It happened to me in a company car it had to go to a body shop for 4 full working days so they could match the paint.
So unless you salvaged the the coloured parts undamaged you are looking at an expensive repair.
From memory the panel should pop off, but try to use something wider than a screwdriver - the correct tool is available. Look carefully for where it’s attached to the door frame before you start.
Thank you - will try a breakers then!
Not looked at the Sandero one yet, put usually, you prise off the inside cover and they tend to have either two or three screws/bolts, holding the whole unit on. It should be straight forward to swap out.
