Not sure what you are asking mate? If you are asking -'is it a good idea to let the car warm up before you drive it?' Then the answer is the same as any other car, never does any harm but not compulsory.
You should always drive off straight away. The engine will warm up quicker and you will use less fuel.
You dont say what engine you have in your car..if your engine has a turbo fitted to it then yes let it idle for a few minutes to make sure the turbo has been fed oil..also when you stop your engine let it idle again for a few mins to let the turbo stop spinning..if you follow that rule your turbo will last a lot longer..
