1 - 3 of 3 Posts
This is a photo from my Duster. The tip of the screwdriver is at the clutch master cylinder. Above that is the rubber pipe carrying brake fluid from the reservoir to the clutch master cylinder. The top pipe marked w/ yellow paint is the vacuum line to the brake booster. There is a rubber boot covering the piston rod inside the car. Check for the source of leakage inside & outside.
Hood Vehicle Car Motor vehicle Automotive tire
1 - 3 of 3 Posts
