Anyone know what the inflation kit consists of. I take it that you get a compressor and something to seal the puncture. Is it a sealant or plugs with fitting tools? I believe some sealants are a problem if you want the tyre permanently repaired later.
I had a look at the inflation kit.
It is a little compressor that you screw a bottle of gunk too and plug into the cigarette lighter.
Seems simple
Sounds like the same thing I had with my Ford SMAX, problem is if it punctures the tyre garage will not repair the tyre until you have cleaned out all the gunk usually!
