Hi, just noticed that my interior/ courtesy lights the 3 in the front and the 2 in the rear don't go completely out when the doors are shut and locked.
They only dim down and you can see very feint light coming from them all.
Only go out completely when they are switched to the off position on the switches. ?
I would report this to dealer sounds like you may have a faulty switch with voltage leak... it will drain the battery over time
In my Duster the lights stay on for a while after you close the door however when you lock the car they switch off immediately (which I think is a cool feature by the way).
So yes, I'd get it checked out, does not sound right.
Just checked them again this morning and they were all off completely but just to be sure I checked with a multimeter and that showed 0 power to them.
Will check them again this evening just to be sure but will definitely be taking it back incase the timer switch is at fault.
