1 - 14 of 14 Posts
Today's job was rather easy, swapping the front indicator bulbs from Amber to Silver to remove the fried egg look.
Difficulty:- Very easy
Before pics
I used these bulbs
ImageUploadedByDaciaForum.co.uk1393088965.729992.jpg remember to use a silvered bulb with an offset pin, 581 is the fitment type
Access to the drivers side is fine,
But due to battery cables access was tighter but easily sorted by disconnecting the adjuster cable temporarily
continued on next post due to pic upload size.
Discussion Starter · #2 ·
The bulb holders twist out
Remember to refit the adjuster cable if you disconnected it
Twist bulb holder back in and job is done. Do the other side and it looks a lot better
£14 from Halfords. Picked there as it was convenient, might be able to pick them up online cheaper. I'll get in about the rear clusters soon once I've located some of the little connectors that got in the factory loom plug. :)
I've put these 'silver' indicator bulbs into all of the cars I've owned,it's a simple but quality upgrade to the standard orange bulbs,looking good NineCherries,and thanks for all the pics you've posted,happy days!
NineCherries,I take it the rear bulbs will be the same as the front.....?? I have found cheaper,mainly on 'fleabay',but as you mentioned,you bought yours the same day,gotta wait for the old online stuff! But as I'm waiting for my stepway,I think an order is going in ASAP......
1 - 14 of 14 Posts
