1 - 3 of 3 Posts
My cel connects with the Medianav and my contacts list appears on the screen ok. However sometimes when I get in the car with the cel and I want to make a call by touching a contact instead of beginning to dial a window opens showing the number and saying "you are going to dial" and the number selected. There is nothing "touchable" on this window and after a couple of seconds it just closes with out dialing. I have to dial from the phone itself nut can then speak through the Medianav system. What's going on? Other times I get in the car and the connection works normally.
Sounds as though your phone may have not connected properly at that point and is veiwing the local copy (on the Medianav) of the contacts. When you dial from your phone its probably then connecting via bluetooth and everything is happy once again.
Might be worth unpairing and then pairing the phone back to the Medianav.
1 - 3 of 3 Posts
