1 - 3 of 3 Posts
£20.98 delivered - you need to buy a memory card as well if you don't have one.
- HD (1280x720) image capture
- Built in 140 degrees wide angle camera
- 180 degrees rotating lens
- 270 degrees rotating display
- 2" LTPS high resolution screen
- Anti shake
- Auto night mode
- Motion detection
- Loop recording
- Micro SD slot ,supports up to 32GB
- USB 2.0 connection
http://www.mymemory.co.uk/Camcorders/MyMemory/MyMemory-HD-720P-Car-DVR-Driving-Recorder-with-140-degree-Wide-Angle-Lens?utm_campaign=HD+720P+Car+DVR+Driving+Recorder+-+Free+UK+Delivery&utm_medium=mymemory&utm_source=spotlight
i had one of these off amazon it lasted 13 months then a burning smell from the battery and then it no longer works So I would buy something better if i was you over on hotdeals they often have one that have been found to be good and cheap ie under 40 pounds
Sent from my iPhone using Tapatalk
1 - 3 of 3 Posts
