Anyone help,
Had a samsung S4 bluetoothed to my medianav, no problems, I've upgraded to an S5 and now can't make a phonecall, it will get incoming calls no problem and if i make a call with the phone it will go through the medianav, but if i try to make a call using the medianav it cuts off and says " this phone cannot service a call" !!!!!????
Not all phones are fully compatible. Have you checked to see if your new phone is listed by Renault/Dacia as being compatible, or if there are any issues noted against it?
Worth checking before you chose a new handset.
I have a Motorola Moto G2 with Android 5.0.2 (not shown in the list of compatible phones) and it works fine. No problems dialling out with the blue-tooth connection. System found all my contacts and loaded them from the phone.
Think it takes Renault a bit of time to catch up with new handsets and while a new unlisted one may well work perfectly, it is a gamble unless you can get to test drive it before buying - maybe someone you know has one.
