1 - 20 of 22 Posts
Sorry but forgot who was asking how to set traffic alerts on normal radio ( not medianav).
Press radio button.
press menu.
Scroll and select RDS options.
Scroll to TA
Select TA ON.
Away you go.
Hope it helps.
Hi tipsthedgehog,
It was I asking how the TA could be set, but unfortunately the info I received didn't work, so I'll try your method & postup the result. Glad I found your post.
I'm trawling through the forum trying to find the thread about the front grill badge being painted a matt black. No luck yet.
Hi again tipsyhedgehog,
Tried your suggestion, but no joy. Via menu, I can scroll to & select RDS, the window then shows AF, REG, & TA, but the scroll wheel wont er, scroll down to TA :angry: .
I set mine using the dial and push button on the radio. Only needed to do it once as I leave it active all the time
On the booklet, all it has is "Radio Classic" TA is mentioned on page 6 & that's it. No indication of how to set it. I've tried 2 suggested ways so far on the forum, but to no avail.
Side question...
When the traffic announcement is happening the screen says something like "press MUTE to exit traffic announcement", so that if you don't want to hear the traffic and want to revert to whatever you were listening to you can do so.
Question is... there is no MUTE button as far as I know.
I have a feeling if you hold the volume up and down buttons on the steering column remote it will "MUTE" but that's only from me applying how it works on other cars.
I haven't yet had a chance to try this but if anyone can confirm the location of said MUTE button - would be appreciated.
Side question...
Both plus and minus volume buttons on stick at same time..
Sent from my XT1072 using Tapatalk
Discussion Starter · #19 ·
Also when the traffic announcement is on and you don't want it on you can press the back/arrow button and it reverts to the radio station again.
When a traffic announcement starts you can cancel it and go back to what you were listening before using the centre mute button on the steering column. Handy for when the local radio starts waffling on about something and leaves it on Traffic mode.
Maybe the jog-wheel on the steering column will also work instead of turning the dial on the radio.
1 - 20 of 22 Posts
