1 - 8 of 8 Posts
I noted today (as it was raining) that my rear wiper screen wash motion does activate when turned the front one is okay.
Has anyone else had this issue with their Sandero (Ambience model)
Peter
Groby, Leics
I've not been driving mine long, so I might be wrong here...
But I know there are two twisty settings for speed. But I think you push or pull the stick to use screen wash on the back? I'll test it on the way home and post later on. Unless someone beats me to it.
Peter
Groby, Leics
when the front ones are activated
if u put the car in reverse
the wiper on the rear automatically wipes the rear screen a few times (usually 3 times)
even thou the switch isnt turned on on the rear
and also if u switch the button from the stick (read user guide/manual) ;)
Peter
Groby, Leics
and if u mean water doesnt come out
u activate the switch then u turn the same switch a bit more to get water to the rear window screen
(its a impulse thing that u do with the hand the button goes a bit further) ;)
Peter
Groby, Leics
Sent from my Nexus 7 using DaciaForum.co.uk mobile app
Up here in the highlands we don't get rain,so I can't be any help---sorry!!
Ok, I've double checked. There are two settings, you twist once to the notch for "go" and then twist it a little bit further past the notch for "sploosh and go"
1 - 8 of 8 Posts
