Does anyone know if you can purchase the original plastic door handle cover in primer or original colour. ?
Obviously they can be repainted easily with a can of spray paint so either option not a problem..
Are these covers unique to the Dacia range or do any of the Renault cars have the same cover or similar that will fit.
I have just lost the plastic cover on the drivers door handle.
FYI they are the same fitment on the Sandero range.
The Stainless steel replacement ones you see advertised only really fit over the existing plastic cover.
The added problem here is the stainless steel ones are only held on with double sided tape.
So if the original Dacia cover falls off you loose the stainless one as well.
Any help here appreciated.
