should there be surface rust on the joint on the steering column, its only 3 days old. slight surface rust, will a little coat of vasiline be ok to use?
thankyou
For some reason that's a web page you've posted not an image sniperkona.
Personally I'd use a little bit of good molybdenum grease that won't melt and run, just to protect the surface but if you're not sure check with your dealer first.
WD 40 rubbed on with a cloth.
But why worry?
It's just surface rust, you'll find that on pretty much any car's steering rack that isn't painted. Unless it's getting wet all the time, it'll never rust enough to cause an issue, would take decades, if not centuries.
