1 - 9 of 9 Posts
Sandero Forum Moderator
Ok the who has a towbar fitted to their Sandero?
If so did you fit it yourself or have it fitted?
Where did you source the towbar?
What were the costs?
Nick
Fitted it myself sourced from Renaultparts but Karl will sort you out mine was about £230 delivered and was fairly easy to fit took about 3 hours A ramp helps lol
It comes in 3 pieces consisting of the tow brackets the swan neck and the wiring kit Which I would highly recommend using as it is bespoke and has the right plugs sockets and bypass for the CAN Bus.
I am intending to fit a towbar too, how do you remove the LH rear trim panels to access the wiring ?
Also does all the underseal need to be scraped off the box section chassis members ?
Jenny
I fitted a cheap eBay one. Onlytowbars was the seller
Was a tight fit but took no more than two hours start to finish, including scotch locking in the universal wiring kit
Sent from my iPad using Tapatalk HD
1 - 9 of 9 Posts
