1 - 1 of 1 Posts
Noticed my seat belt warning light was on all the time, even with passenger in car, so tested tightness of connectors, then switches where belts clipped in, so far all seemed OK, so on closer inspection, I found that a wire had broken away from a sealed connector, which was situated under the seat trim, right hand side, bottom of passenger seat.
There are two blue wires that are connected in the opaque rubbery seal, so snipped remaining wire away, trimmed the covering back to expose the two pins, and soldered them back onto the pins. The two wires connect into the pressure pad in the seat.
The wire had probably broke due to the rear passengers feet being in contact with it, as it was not secured to the bottom of the seat properly.
1 - 1 of 1 Posts
