Hola. We use the car more off road than on and the rear seat is a right bloody mess ;)
Is it a difficult job to take the seat out to wash it ?
In previous cars of other makes, there was a tag to pull at back of the seat by the belts to lift the seat up.Then the pins could be removed.
It would appear that you might have to use your own initiative - as I had to! Unlike many 5-door cars, the seat base on my Stepway cannot be pulled forward and out of the way when the seat back is put down, which limits the space available. I presume because of what you're asking that the same applies to the Duster. So perhaps you should do what I did when I wanted to put some sound proofing under the base - put your hand where the back joins the base and pull up!
