1 - 3 of 3 Posts
I went to Arnold Clark yesterday to be told the Dacia speaker mounts were £50; I've had a look (and whilst I'm happy with a jigsaw) I found these: http://www.sonicelectronix.com/item_39184_Xscorpion-USPA-5060.html
Off to find a UK supplier, but do you think they fit? @Plissken - you've made your own mount.
-- Edit 14:45 16/03/2014 --
Seems these speaker mounts (and cables) fit the 2012 Sandero, http://www.ebay.co.uk/itm/380740284495 , and I decided to give LiquidIce my speaker business too.
Was going to suggest giving ebay a whirl, I had seen these and was going to give them a punt.
Please report back as I will need to do the exact same when I get my Sandy ;)
So, full write up. Do the head unit, then do the door, the screws look the same but have different threads.
Head unit went in easily, as per usual. There is a surround to the fascia panel on the Logan Access that I might have snapped some clips off. Fitting kit.
Speakers, removed the c-clip on the winder first (fold a tea-towel in half, slide it in the gap, spin it round and it'll pop off). There's a metal clip holding the door panel under the wing mirror adjuster, remove all the screws (locking edge, handle, panel screw), then there are clips in the door. I pulled a little too hard, then worked out I could fit a tool in and pop them out. I cut the foam off, and pulled the wire through. Fitted these speaker mounts using the metal clips from my speakers and screwing slowly. I've "fitted" these 6.5" speakers, they're too big against the door cross member and push out about 7mm too much.
1 - 3 of 3 Posts
