1 - 9 of 9 Posts
My new Sandero ambience 1.2 has developed a knocking noise when turning into corners and when reversing into drive has any one else experienced this. It is under warranty and I will be contacting the dealer.
Knocking when cornering is a sign of a issue with a ball joint or cv joint, but it would just be on one side of the car..
If you are getting the knocking on both sides, I am not so sure. Anything to do with steering you are not sure about you should get checked out ASAP, It could be something catching on your tyre or something serious... When it comes to steering you need to be confident with it.
If its a relatively new car, get it checked & fixed under warranty,
Thanks nessi
Don't take any o its fair wear and tear excuses.... Its only --- old, Its only done --K miles, you have not had a reasonable amount of use to cause fair wear and tear...
But "Good Luck" hope you get it sorted with no Fuss.
1 - 9 of 9 Posts
