Having checked your tyre pressures did you reset the computer? Right hand stalk click until you get to SET TP then click and hold the end button until it flashes. Turn off the car and turn on and it should clear / reset.
Is your car direct or indirect tpms? When tpms became compulsory 1 Nov '14 Dacia used direct for about 1 year before switching to indirect.
Direct uses a sensor in each tyre so if you have that the batteries could be nearing end of life. Unfortunately they are not normally replaceable and you will need a new sensor.
2020 Sandero Stepway II, 1977 MGB Roadster
Set the tyres at say 30psi, and register it with the stalk as before. I think, from memory, you are then supposed to run it up and down the road. Then put, say, another 3psi in the tyres and see if the light stays off.
Might be worth a try before you start spending.
Or am I barking up the wrong tree?:confused:
