1 - 2 of 2 Posts
Hi wondering if anyone can help i have a 15 plate dacia duster. When it's raining water is coming in somewhere and soaking the rear passenger carpet. All door seals have been checked and they are fine. Has anyone had this issue? And if so is it an easy fix problem?
37072
Check underneath that there are no rubber floor gromits missing, other than that do what I did, my tailgate was filling with water, I stripped off the plastic and sat inside the boot, got Mrs to pour water on the tailgate so I could see where the water was getting in, in your case I would lift the carpets, dry off the floor then sit in the back and get someone to use a hose or watering can over the top of the car then hopefully you will see where the water is coming from, remember, if there are no missing floor gromits then the area you in your pics is the lowest point in the back of the car, water may be getting in further up and running to there.
1 - 2 of 2 Posts
