Hi I have 2013 Duster D1.5 DCI just need to know what oil I need to use . As cannot find info in my handbook it says refer to manufacturers service book which I do not seem to have been given ? I noticed the oil light stays on in ignition, however it does go out once engine has started does that sound ok or is there a fault?
hi was told by dealers 5w 30 that what i use and as for oil light mine goes off about 5 secs after started engine
My dealer here in sweden used a ACEA C4 oil 5w-30.
The light goes off when the pressure is high enough..
mine also stays on for a few secs.
The oil light will stay on for a few seconds until it gets up to pressure or slooshed around the engine or whatever the term is.
Here's an excerpt off my 'Warranty and Service' sheet for my 2013 DCI, you can see the oil spec there:
There is also a thread here about using C3 or C4 spec oil
