1 - 3 of 3 Posts
I found that the pressure from the front screen washers was always a little suspect so i flushed out the washer bottle with a hosepipe and plenty of muck came out (residual screen washer additive that had turned to scum) but the washer pressure only squirts water at the lower part of the screen. Is this normal with the Duster or do i need more investigation or a better pump?
I collected my Duster last Friday, so still finding my way around it. The washer jets were spraying low and I didn't fancy trying to adjust the 3 jets in each with a pin like you usually have to do. I noticed that each nozzle has a slot on the side to adjust the height of the jets, it takes a small flat blade screwdriver and job done.
Have a check on yours, they could be the same - on passenger side of each one.
Boba. So much for dealer doing pre inspection on ur duster before del to customer (height of water jets )wat else they not done ???
1 - 3 of 3 Posts
