The handbook for my UK Duster 4x4 does not mention any speed restrictions for changing between 2WD and 4WD.
The mode selector should not be turned whilst cornering, reversing or if the wheels are spinning.
4WD lock reverts to Auto mode above 36mph (60kph).
Well I was messing about today whilst driving along, switched to 4WD lock and low and behold it drops out @ 50 mph not 36mph (well mine does) ..... I agree with 2dusterchris the manual states 36mph (I read it today) ?????Top one 2duster, I wasn't too sure of the speed, as I intimated earlier it was off the top of my head, so 36mph it is.
agreedThing is Antavi I don't think that is what they have done, looks like a mistake/error/slip-up throughout lots of nationalities manuals; It would invite confusion and a lack of trust in all else in the manual ... saying one thing and doing another.
But they have put the 'safe area to operate in' and a 'safety system' to ensure that that area is not exceeded with the auto cut-out back to 2WD @ >50mph, I would rightly assume far below the limit where damage may be caused.
All that said, why would I use my 4WD at higher speeds anyway, for me just at low speeds when the situation dictates it would be more prudent.
Chris is correct, I use my Duster for towing and it is recommended to drive in 4wd auto mode on all surfaces wet or dry and it does not drop back into 2wd at certain speeds, only when it is in lock mode which will drop into auto mode. This is why the 4wd Duster has a higher nose weight for towing. 4wd Duster is 75kg and the 2wd Duster is 50kg.The 4wd system on the Duster is able to transfer power to the back wheels when there is excessive weight is on the back such as a caravan, this stops the wheels from losing traction if the front end becomes light. The Dacia manual explains in detail when to use the 4wd modes, there is an odd bit about driving over bridgesThe handbook for my UK Duster 4x4 does not mention any speed restrictions for changing between 2WD and 4WD.
