Duster problem
112 views 5 replies 2 participants last post by  leonardermo
#1 ·
Hi everyone,I have a 2015 diesel Duster which has developed a fault. For the last few weeks, I have noticed a occasional slight squeal from under the bonnet but yesterday the yellow engine malfunction warning light came on and the car lost power for a while, also the squeal became very noticeable at the time. I plugged an OBD reader in and it came back with fault number P1494 which apparently is related to a EVAP fault but I don't think a diesel engine has this system? Cheers.
#4 ·
U need to have a scanner w/ specific Renault/ Dacia software.
That code could also refer to the EGR solenoid valve in some cars.
U have to find the source of the `squeal', such as the accessory belt or water pump.
#6 ·
OK,thanks,as a matter of fact,I think now that maybe the problem is the EGR valve,I will clean it,hopefully it will solve the problem
Ive
I've cleaned the EGR valve now and the problem seems to have gone away,thanks for your help.
