Main lights not working
1 reading
2.8K views 6 replies 4 participants last post by  Merelamur
#1 ·
Hi, few days ago my main lights stop working. Took my car to the dealer and they said the lights were a bit loose, by the time I got home one of the lights not working again. My question is my car is in warranty so I understand the lights getting lose are due to a fault as the car had no damage, bumped or anything that could provoque this. Will the warranty cover it if the part (holding the bulbs) needs replacement?
Thank you
#2 ·
Unless you have damaged the bulb holder yourself, then yes I would push them to repair or replace under your warranty. When you book it in, get the service technician or desk clerk to come out with you to your car so you can show them, rather than being fobbed off with something like it was fine or couldn't replicate your error.
#3 ·
You don't say the year of your car. If it is the "old" Sandero II the lighting stalk is notorious for giving faults. It is an easy replacement and should be done under warranty. It is also a known fault on the Clio IV which uses the same stalk.
