Well, here we are again,this time with a reason and a solution to the knock.
After putting my car into a garage for over a year, from new, trying to find this knock, i got onto Renault customer Care, they suggested a fresh look at the problem at a different garage. By a lot of good investigation, and help from Renault techie guys, the reason for the knock was found to be the Bulkhead flexing, the solution was to stick on noise damping to the engine side of the bulkhead, problem solved knock gone.
I subsequently had a call from renault, during which i asked if this was a safe fix or a quick fix, answer was, safe.
This is the first time i have come across this problem, and i know that bodies are meant to flex, so much, but i just can't help thinking this is a bit weird, any opinions on this.
Regards, Jim.
